Hello Guest it is November 12, 2026, 08:12:59 AM
Author Topic: Outputs can't be active low?  (Read 15661 times)
« on: July 20, 2009, 11:20:04 AM »
Has anyone had trouble getting the galil outputs to work configured as active low in the ports and pins screen?  I'm running an 1832 card and need 7 outputs to be active low, one to be active high, but all function active high regardless of which way the boxes are checked...  Thanks for any ideas...
Offline smurph
  •  1,575 1,575
Re: Outputs can't be active low?
« Reply #1 on: July 21, 2009, 12:16:04 PM »
It looks like the outputs don't take the active low config from Mach.  I'll fix that up tonight.  PM me with your email address and I'll get you a plugin that will work for you.
Steve
