Hello Guest it is November 13, 2026, 09:51:56 AM
Author Topic: Toolpath display problem  (Read 10891 times)
« on: July 20, 2009, 08:11:38 AM »
This my first post asking for help as I am brand new to the CNC world. I've just finished setting up my machine and configuring Mach3. Everything is working, but whenever I load Gcode, the toolpath is zoomed out extremely far. I have to zoom in more than a dozen times before I can make out the path.
I've loaded several Gcode files, with the same results on each. I loaded roadrunner file and after zooming in so that I could see, ran it and it had no problems.
I assume I have inadvertently changed a setting, but don't know what it might be.
Any help would be appreciated!
Re: Toolpath display problem
« Reply #1 on: July 20, 2009, 09:38:32 AM »
OK, I may have figured this out (I'm at work right now and cannot verify). I think I need to set my table size in the Homing/Limits parameters. It hit me when watching the video tutorial for the second time that I did not do this. It's really amazing when that little light bulb goes off!
Hoping it will be this simple.
« Reply #2 on: July 20, 2009, 10:36:52 AM »
just zeroeing the work offset coords where the zero of the part is wanted should help you :)
