Hello Guest it is November 13, 2026, 12:14:10 PM
Author Topic: Stopping and resuming  (Read 24027 times)
Re: Stopping and resuming
« Reply #10 on: July 17, 2009, 03:56:49 PM »
I will do some experimenting but I don't think I lost steps.
I will also confirm that machine coordinates are set as I said. I'm on the home computer so I will need to confirm that the setting is set to machine coordinates but I am pretty sure that this is the case.
I will report back after I have a chance to check this.
Bill
vmax549
« Reply #11 on: July 17, 2009, 04:04:25 PM »
check and see if your machine cords are where you think they are. Set mach to mach coords then creep up to the limit switch and check the values
« Reply #12 on: July 24, 2009, 05:00:57 AM »
I found that my Safe Z Setting was set to Machine Coordinates. I experimented and changed it to Work Coordinates and Z now moves to +.2 above the work as I want. I guess since I don't use a Home Switch set up (at least not yet) that I don't use Machine Coordinates. I'm a NewBee.
I experimented with the Run From Here command again and it did work although at this point, I will keep my hand on the emergency shutoff when I try this due to lack of confidence. It's a little scary. Ha!
Now I have a question regarding Backlash settings that I will post in a new thread.
Thanks!
BillJ
