Hello Guest it is October 30, 2026, 09:50:04 AM
Author Topic: New Interface in Italian and in English for Mach3: Itascreenset V. 2.0  (Read 39492 times)
Hello to all. I finally finished the new interface in Italian for Mach3. To install unzip the file setup.zip and launch the program setup.exe. Regards, Giordano Cantori.
« Last Edit: August 02, 2009, 04:51:10 PM by giordano »
Re: New Interface in Italian and in English for Mach3: Itascreenset V. 2.0
« Reply #1 on: August 11, 2009, 11:01:34 PM »
Wheres the link?
« Reply #3 on: August 12, 2009, 11:49:12 AM »
Very nice work -  :)
« Reply #4 on: August 14, 2009, 10:56:18 PM »
good mornig,
realy good screen for Mach3.
Thank you.
« Reply #5 on: September 17, 2009, 10:32:47 PM »
Dear giordano
         There is no English translation at Job Control Screen. I see it is in Italian Language. Please translate and modify if it possible. Thank....
High Tech Key
« Reply #6 on: September 18, 2009, 06:55:26 AM »
Hello High Tech Key. To test, now I installed the translated version downloaded from the link provided and it works perfectly. Giordano
« Reply #7 on: September 19, 2009, 09:47:30 AM »
Dear giordano
         I had already downloaded your Italian English screenset and testing. It is a great work. But you have left some translation for english at Job Control screen. Do you understand what I mean? My english skill is a little bad. So, I upload some picture for this screen. It is also left at "Set step per unit" button in "Setting" mode. I also upload this photo. Please translate and modify for this if you are OK. Thank.
High Tech Key
« Reply #8 on: September 20, 2009, 10:34:34 AM »
Hello, I'm sorry but I did not understand the problem. I had not noticed this oversight. Thanks for reporting. Attach the file to install updates. After unpacking the archive, rename the file setup.dat to setup.exe. Regards, Giordano
