Hello
Guest
it is
November 22, 2026, 08:26:05 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
CV distance
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: CV distance (Read 10659 times)
el4al
5
CV distance
on:
May 24, 2009, 05:26:08 AM »
HI... just wanted to know can I set the CV disance to 1 instead of 180 ?
Logged
SteinarN
155
Re: CV distance
Reply #1 on:
May 24, 2009, 06:14:54 AM »
Yes, you can even set it to a decimal value like 0.3 if you like. You probably should set it to a value like 0.05 or something like that if your units is inch and you don't want it to "cut" your corners to much.
Logged
Print
Pages:
1
Go Up
« previous
next »
