Hello Guest it is November 22, 2026, 07:43:29 AM
Author Topic: Lost communication with PLC after SS instal  (Read 43012 times)
Re: Lost communication with PLC after SS instal
« Reply #20 on: May 21, 2009, 12:50:49 PM »
hooking it up now , fingers crossed
« Reply #21 on: May 21, 2009, 12:55:13 PM »
You can connect that to any input you wish whether on Port 1, 2 or 3 of the SS, it is only if you have a differential input, and want to use it,  that you need to use Port3.
 Whichever you connect it to you just set the Index in Mach to that port and pin just as you did when using the parallel port.
« Reply #22 on: May 21, 2009, 12:58:19 PM »
much thanks , seems to be working like a champ
« Reply #23 on: May 21, 2009, 12:59:43 PM »
« Reply #24 on: May 21, 2009, 02:40:53 PM »
just cut the first half a dozen test threads and they look just perfect
