Hello Guest it is November 13, 2026, 08:05:18 PM
Author Topic: Timing  (Read 23277 times)
Timing
« on: May 13, 2009, 02:18:25 PM »
Help please,
Having installed a timing disc on my C1 style lathe, in accordance with the instructions in the Mach3 manual, I have a problem. I calculated the slot width according to the manual(3mm on a 99mm disc), I know it's right, the wife checked it. The software returns an accurate RPM for the spindle (exactly the same as my optical tachometer) up to about 200RPM. Beyond that, no increase in the registered speed. Any one any ideas as to what I should do?
Ian Hart
Re: Timing
« Reply #1 on: May 13, 2009, 02:41:25 PM »
Increase the slot width to approx 10mm and it should work fine.
Re: Timing
« Reply #2 on: May 13, 2009, 05:42:59 PM »
Isn't it a bit extreme when Mach3 says 3mm?
IanH
Re: Timing
« Reply #3 on: May 13, 2009, 06:18:41 PM »
Just what I have always used and never had an issue, lathe goes to 2000 and mill to 5000 and both are rock steady.
Re: Timing
« Reply #4 on: May 13, 2009, 06:59:09 PM »
Ianh,
Mach needs a pulse duration that is long enough to read, so, the faster you go the bigger the slot required relative to disc diameter.The electronics associated with it all has some time also. So I would consider what is in the manual a good ball park calc for the width.
Don't remember, had the same problem of reduced display at one time, but one of the versions cured the readout with no change in the slot width as per calc. This was for a single slot for index.
The four slotted timing disc i use has three small per calc and one twice as big and works fine.
I'm using Ver2.042.27 for the lathe FWIW.
Re: Timing
« Reply #5 on: May 14, 2009, 02:56:54 AM »
Thanks for the helpful responses, I'll try later.  Son arrived yesterday asking that I take him and wife for 'jolly' driving a Ferrari so today's playing in the workshop is out!
Ian H
Re: Timing
« Reply #6 on: June 25, 2009, 05:12:15 PM »
Ian H
hello, did you get anywhere further with this issue yet?
Re: Timing
« Reply #7 on: June 26, 2009, 06:25:35 AM »
Thanks for the continued interest.
I have increased the slot width to around 10mm and now it reads, still accurately, up to around 300rpm.
Should I create three small slots as well?  Mach3 says that it should work with just one.
IanH
Re: Timing
« Reply #8 on: June 26, 2009, 07:25:24 AM »
What type of opto are you using?
Re: Timing
« Reply #9 on: June 26, 2009, 11:10:15 AM »
Hello again
The spec. sheet that I was given when 'friend' ordered the optoswitch is for a Honeywell HOA7720/7730 (Connectorized Transmissive Optoschmitt Sensor)
Ian Hart
