Hello Guest it is November 02, 2026, 09:29:45 AM
Author Topic: need a hints "how to do" if possible ...  (Read 8288 times)
« on: May 12, 2009, 11:44:36 AM »
i need a feature and i'm not shure if it's possible:
when i'm on the MDI-Screen to lit a LED isn't a problem (or any other screen)
but to lit a LED (or activate an output) when on any screen the MDI-line is opened (waiting for input) - possible in any way ?
Regards Frank
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: need a hints "how to do" if possible ...
« Reply #1 on: June 02, 2009, 10:51:23 PM »
I'm not exactly sure of the issue you are having but you could create your own MDI input if you like:
Past this code on a Button:
Code: [Select]
Private Sub cmdok_Click()
Dim ans As String
MyGCode = InputBox("Enter Gcode", "My MDI")
If MyGCode = "" Then
MsgBox "Gcode Canceled"
Else
Code MyGCode
End If
End Sub
« Last Edit: June 03, 2009, 04:45:11 PM by zealous »
