Hello
Guest
it is
November 13, 2026, 07:57:12 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Help with torch up down
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Help with torch up down (Read 10864 times)
fourxfour2
36
on:
May 11, 2009, 04:22:18 AM »
okay I have a problem...going through the brains on the torch up and down comand the Z axis is very jumpy.
also have up and down Leds on screen set with THC enable button & led and none seem to do anything...have not tried it with g code just on test bed...Maybe Scott AKA poppabear can help with this?
if he has time...
If I use the shuttle All axis are smooth and liner....it is only when the brain turns on the torch up or down...
Thanks for any help
Last Edit: May 11, 2009, 03:07:15 PM by fourxfour2
Logged
tripleblack
128
Re: Help with torch up down
Reply #1 on:
May 12, 2009, 09:00:58 PM »
hi, on the mach plasma main screen , under the thc on button, there is a setting to control how fast mach moves the z axis. i have mine set to 5.
Logged
Print
Pages:
1
Go Up
« previous
next »
