Hello Guest it is November 28, 2026, 12:13:39 AM
Author Topic: Adjusting screen size  (Read 11624 times)
JDolecki
« on: August 10, 2006, 11:46:58 PM »
I have been luckey enough to get a small industrial computer with a built in touch screen but i cannot seem to adjust the screen size to make mach3 fit on the screen what am i doing wrong?
Re: Adjusting screen size
« Reply #1 on: August 12, 2006, 07:52:22 AM »
Did you check the auto screen enlarge under the settings?
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: August 12, 2006, 12:17:51 PM »
What size is the screen? and whats its resolution? you may need to load the 800 screen if thats what your resolution is (800 x 600 ).
 Not sure how you will get on if it is a small screen as I think hitting the right buttons will be a pain. I have a 17inch touch screen (1024 x 768 resolution) and I made up my own screen with bigger buttons, made using the touch screen much better.
