Hello Guest it is November 08, 2026, 03:01:46 AM
Author Topic: Problem cutting circles  (Read 25600 times)
Offline allyd
  •  24 24
  • Aussie Aussie Aussie
Re: Problem cutting circles
« Reply #10 on: May 25, 2009, 12:39:44 AM »
Just a quick update to my circle cutting problems.
I basically have not idea how or what fixed it but the changes I made were:
1. Fitted a SmoothStepper
2. Fitted shielded cable for the spindle motor from a junction point to the Spindle motor.
The smoothstepper has allowed me to increase my resolution from 143 pulses / mm to 259 without sacrificing speed and the shielded cable was what I should have fitted first time around.
Thanks to all who responded, I have been cutting perfect circles all weekend.
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #11 on: May 25, 2009, 11:23:45 AM »
SteinarN - I am coming in late to this post - it appears finished - but - YES - Mach 3 supports backlash compensation. You cvan measure your backlash on each axis and put the data in Config/Backlash. If you turn backlash compensation on, the Mach 3 will allow for the backlash every time your acis changes direction.
