Hello Guest it is October 20, 2026, 03:08:47 PM
Author Topic: Screen Works But won't run My CNC Maching  (Read 9922 times)
celticbern
« on: August 06, 2006, 11:30:02 AM »
Hello All..
For some reason I screwed up my computer to control box.....The Mach 2 screen shows the x,y,z moving when I press the HOTKEYS but it will not move the CNC motors....I must have locked out something or pressed the wrong key.
I double checked all cables etc and still nothing.
I have been using Mach 2 for a long time for my Irish and Celtic Wood Carving Rough Outs and it is wonderful.
I cannot figure out what I locked out but any input will be greatly appreciated.
Kindest Regards,
Bernie Fay
http://Http://www.carvingceltic.com
Re: Screen Works But won't run My CNC Maching
« Reply #1 on: August 06, 2006, 01:51:18 PM »
Sounds like your port or pins have been screwed up, check that all the pins are configured correctly and that they are all enabled and assigned to a port. Also make sure the port address in Mach is the same as it is in device manager.
