Hello Guest it is November 27, 2026, 12:28:44 AM
Author Topic: Making a DRO read-only?  (Read 19731 times)
« on: April 22, 2009, 11:45:02 AM »
I'm trying to find a way to make a given DRO read only.  I'm populating the DRO with the results of a formula using values input from other DRO's and it seems that allowing this particular DRO to be edited just causes confusion for users - it doesn't really harm anything, since the user-input value is just overwritten, but for usability's sake I'd love to make the DRO non-editable.
Is this possible?
Apologies if this one's obvious - I've tried searching with a few different terms, but the results of a search for DRO and edit aren't exactly helpful in this case.
-Matt
Re: Making a DRO read-only?
« Reply #1 on: April 22, 2009, 01:01:17 PM »
Dont think it is possible I am afraid.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #2 on: April 24, 2009, 09:26:15 AM »
you might try to put a transparent button over the top of the DRO  ;)
« Reply #3 on: April 24, 2009, 09:27:12 AM »
I haven't tested this yet.... but you might try to put a transparent button over the top of the DRO  ;)
Thanks for the idea.  I'll give that a shot and let you know if it works.
« Reply #4 on: April 24, 2009, 10:05:58 AM »
If it works, you can make the button run a script to alert the user that the DRO is read only.
« Reply #5 on: April 24, 2009, 11:23:38 AM »
This program and it's capabilities constantly amazes me!
Seems you can do everything with it.
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #6 on: April 24, 2009, 06:39:30 PM »
Acualy,
Since you are writing the code...send it to a User Label they are read only from the GUI.
Code: [Select]
myResults = "some stuff"
SetUserLabel(10, myResults)
« Last Edit: April 24, 2009, 06:42:01 PM by zealous »
« Reply #7 on: April 25, 2009, 12:06:57 AM »
Sorry for this stupid question.
What is GUI?
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #8 on: April 25, 2009, 12:16:38 AM »
GUI is = Graphical User Interface
You can write to UserLabels using script but you can not click on them with the mouse to enter in values from the Mach screen.
