Hello Guest it is November 27, 2026, 04:56:22 PM
Author Topic: cannot load the full gcode file into mach3...  (Read 13821 times)
« on: April 16, 2009, 11:52:49 PM »
Hi
i cannot load the complete g code file into the demo version of mach3... the file originates from DeskProto software
and at  the below... stops loading
G1 X8.584 Y8.216 F700
G1 X8.805 Y7.995
about 1/10 of the file is being loaded
any ideas... the file is attached
Re: cannot load the full gcode file into mach3...
« Reply #1 on: April 17, 2009, 12:01:06 AM »
The Demo version is limited on the amount of code you can run.
Thats a BIG file.
RC
« Reply #2 on: April 17, 2009, 03:31:42 AM »
that expains it ...
thanks
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
« Reply #3 on: April 17, 2009, 07:49:01 AM »
Yep, you just need to purchase a license to load a file that big. The demo allows you to run enough code to see how well it will work for your application, which I have always kind of liked. You can get purchase a license from the 'Support' tab on this site or from a Mach dealer. IHMO it is a great value.
Happy machining , Jeff Birt
