Hello Guest it is October 24, 2026, 03:46:14 AM
Author Topic: Can two 36v power supplies be used in series to get 72v?  (Read 124688 times)
Re: Can two 36v power supplies be used in series to get 72v?
« Reply #40 on: April 24, 2009, 01:52:02 PM »
This is my new power supply. So far, I know is is unregulated, I think it is toroidal, and I still have no idea what linear means.
"The reason I was asking is if you had a linear supply that had a Toroidal transformer, this looks like a Large donut BTW, you can quite easily take off windings to tailor it to the voltage you need."
How does one go about finding and taking off the 36V?
« Reply #41 on: April 24, 2009, 02:18:07 PM »
That looks like the AnTek version, I buy my Toroidal transformers from him, like the one in the rear of the picture.
Linear has come to be the description for any  transformer-bridge-capacitor supply, but technically it would normally have a series pass transistor or? for linearly (non-digital/switching) control of the DC output.
The tailoring of Toroidal transformers is fairly easy, you have to know the turns/volt to know how many turns to take off, say you wanted to reduce a winding by 10v output and the transformer had 2turns/volt, then removing 20 turns would do it, turns can also be added to increase the output also. Or you can add a completely separate winding, as long as you do not exceed the total VA of the transformer.
If you want to find out exactly before hand, then wind on a small conductor of 10 turns and measure the AC, the math can then be done.
« Last Edit: April 24, 2009, 02:20:55 PM by NosmoKing »
« Reply #42 on: April 24, 2009, 10:04:07 PM »
You can use a voltage doubler circuit if your transformer has extra current capacity.  Get some 40V 22000 mf capacitors , remove the +wire from the Bridge rectifier and connect it to one side of the AC transformer lead this will be your 36v positive lead  . Connect the  minus side of the new capacitors to the +side of the old capacitor connect the + terminal of the Bridge Rectifier to the + side of the new capacitors this will be your 72v line.
« Reply #43 on: April 25, 2009, 12:08:41 PM »
Thanks for the info.
Situation has changed and now I need to run a 36V motor off the 72V power supply. Can that be done in a similar way with a 'votage halver?"
« Reply #44 on: April 25, 2009, 12:19:59 PM »
If you use the voltage doubler you will have both 72v and 36v outputs.
Robert
« Reply #45 on: April 25, 2009, 02:19:34 PM »
Robert
He has a 72V power supply, not a 36V supply.  He doesn't need a 144V supply....
« Reply #46 on: April 25, 2009, 02:28:01 PM »
I think if he can find a zener diode that can handle this voltage at the current he needs, then it would be the best solution...
Daniel
« Reply #47 on: April 25, 2009, 02:36:54 PM »
Daniel
That would be one bloody HUGE Zener diode, and it would be *constantly* dissipating as much heat as the motor running full load.  There is no easy way to get 72V down to 36V at the kind of currents required by a motor.  It requires a regulator.  The only viable solution is to buy a suitable 36V power supply.
« Reply #48 on: April 25, 2009, 04:24:02 PM »
If it has a toroidal transformer then there is a chance it has two 25v outputs in series.
 Now I know very little about this kind of stuff but would taking a tapping from one of these secondaries and then rectifying and smoothing not do the job? Of course it may have two 50v secondaries wired in parallel or indeed just have a single secondary but most toroidals I have seen have the two.
 Then again its probably just as easy to build a second power supply and not have to worry about exceeding any limits..
« Reply #49 on: April 25, 2009, 04:34:49 PM »
It does appear to have dual outputs, so it may be worth investigating the AC secondary voltage values, it would not be hard to modify.
