Hello Guest it is October 15, 2026, 10:31:35 PM
Author Topic: step error  (Read 50662 times)
Re: step error
« Reply #30 on: May 13, 2009, 12:27:20 PM »
That is better than I would have expected but in reality no where near enough for a machine tool such as a mill or a lathe even if you do manage to get it as good as 0.02mm. I think I remember you saying it was a granite cutter you have, that kind of accuracy is more than likely much better than you need :)
Re: step error
« Reply #31 on: May 17, 2009, 08:25:31 AM »
thanks a lot
can u help me for the accurate and best way for home switch r it limit or proximity switch or photocell or other
Re: step error
« Reply #32 on: May 17, 2009, 08:31:08 AM »
probably an optical switch would be the most accurate but it would depend on the environment whether it would be the best. If there is a lot of dirt and dust then and optical would need to be enclosed and the flag operated by a plunger which exits from the side of the encosure so that dust isnt a problem.
 You may be better with a prox switch if it is no magnetic material you will be cutting, they can be accurate as well.
