Hello Guest it is October 24, 2026, 10:49:30 AM
Author Topic: Axis works update.  (Read 23549 times)
Axis works update.
« on: April 10, 2009, 03:33:53 AM »
If you are like me and have had your dspmc powered machine up and running for a while, you probably haven't had to use axis works in a while.
Well, I am doing a lathe conversion using the dspmc and I downloaded a fresh copy of axis works, the #59 firmware, the matching plugin, and the .043 mach development code because I want the new features.
I opened axis works and connected to the dspmc. What a new look. The axis graph is right on the front page, not a popup anymore. You now have the ability to toggle the ouputs from axis works. This allows for setting up the basic I/O directly from axis works, without having to go into Mach3.
After talking to Rufi, he is going to add a selection for I/O only in axis works so you can hook up without having to select an axis or woory about moving motors, just work on the I/O.
Mike
