Hello Guest it is October 14, 2026, 03:56:03 AM
Author Topic: Corrected problem of positive shift not being shown on DRO's  (Read 121421 times)
Offline lokey
  •  60 60
Re: Corrected problem of positive shift not being shown on DRO's
« Reply #20 on: April 18, 2009, 08:20:14 PM »
Hi, I tried the suggestion and there is still a accumulating positive shift of 0.0015 .
Offline Greolt
  •  956 956
« Reply #21 on: April 18, 2009, 08:56:28 PM »
OK set velocity to 30 and acceleration to 5 and try again.
You still have not told us your driver, power supply and break out board setup.
Explain how you are measuring the 1.5 thou discrepancy?
Post your XML.
Greg
« Last Edit: April 19, 2009, 05:14:23 AM by Greolt »
Offline lokey
  •  60 60
« Reply #22 on: April 19, 2009, 11:08:19 AM »
“OK set velocity to 30 and acceleration to 5 and try again.”
I did the suggested resets and there is still a problem.
“You still have not told us your driver, power supply and break out board setup.”
The control box and power supply came with the Zenbot.
“Explain how you are measuring the 1.5 thou discrepancy?”
Method for measurement:
1. I secure  a heavy metal plate to the tooling bed.
2. Attach dial indicator with magnetic base to plate.
3. Home all axis and zero display.
4. jog to dial indicator G0 X2,Y2,Z-2 and zero the indicator
5. Home axis G28
6. Jog back to dial indicator G0 X2,Y2,Z-2
7. This is where dial indicator starts showing the accumulating positive shift of +0.0015
8 repeat steps 5 and 6 the error increases a constant +0.0015 after each repeat and the error does not show up on the DRO’s
If I use the same method but replace G28 with G28.1 X-0.0015 Y-0.0015 Z0.0015 then no error occurs.
I did notice that when I use G28.1 the DRO’s do not reset to zero but reset to + or - 0.0009. They should reset to zero after a G28.1 command. That is why I had to reset the DRO’s to zero so many times within the macro.
“Post your XML.”
I posted the XML and I am continuing to review the config Mach3 pdf . Thanks again for efforts and best regards.
Offline Greolt
  •  956 956
« Reply #23 on: April 19, 2009, 05:12:56 PM »
You have posted the wrong XML.  That one is blank.  No settings.
Post the XML that you are using.
Greg
Offline lokey
  •  60 60
« Reply #24 on: April 19, 2009, 06:00:39 PM »
Hope this is the correct one
Offline Greolt
  •  956 956
« Reply #25 on: April 19, 2009, 06:33:15 PM »
"The control box and power supply came with the Zenbot."
Need a better answer than that.   :)  How about some details?
I think it is very unlikely that your steps per unit is correct.
The chance of it being a nice round number like 1112 when using a belt dive is, to my mind, almost impossible.
That would easily explain a 0.0015" discrepancy.
Greg
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #26 on: April 19, 2009, 06:38:47 PM »
I do not see how a G28.1 can fix your problem, all it is doing is homing the machine via an intermediate point X0.0015" etc.
If you change the X value to X-2. you will see what I am saying. The X axis will move 2" away from home and then home.
Have a look in your fixture offset table and see what is in G59.253 and above.
Graham
Offline Greolt
  •  956 956
« Reply #27 on: April 19, 2009, 07:16:31 PM »
Graham
Lokey does not have home switches so in effect he is simply adjusting the machine coordinates by the 0.0015 amount each time.
Moves to the intermediate point and the zeros the machine coordinates without any further movement.
Greg
« Last Edit: April 19, 2009, 07:41:27 PM by Greolt »
Offline Greolt
  •  956 956
« Reply #29 on: April 19, 2009, 08:00:27 PM »
RC
Lokey is not online right now.  I am presuming that is the one.
Greg
