Hello Guest it is October 11, 2026, 05:47:27 PM
Author Topic: Rectangular Shape  (Read 12874 times)
Rectangular Shape
« on: April 04, 2009, 12:28:28 PM »
I have a very large machine that I am setting up and fine tuning and I do rectangular with 4 square corners test file run. On the Mach screen and the machine run with 3 round corners as you can see from the screenshot.
Can you please tell me what cause that?
Willy
Re: Rectangular Shape
« Reply #1 on: April 04, 2009, 04:06:08 PM »
Probably CV mode.
« Reply #2 on: April 05, 2009, 01:14:55 PM »
For external corners, I always prog to roll the cutter round the corner. Its much gentler on the machine?
Might also help with your problem?
ATB
Derek
You can "chop it off" but can't "chop it on"
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #3 on: April 06, 2009, 11:52:18 AM »
Put a G61 at the start of your g-code, that should stop the rads.
Graham
