Hello Guest it is November 13, 2026, 08:05:07 PM
Author Topic: Muti-start threading....  (Read 86770 times)
Offline Tef9
  •  89 89
Re: Muti-start threading....
« Reply #50 on: May 08, 2009, 09:26:00 AM »
Ok will give it a go tonight and report back, I think my z axis is moving too quick!
A
« Reply #51 on: May 08, 2009, 09:30:21 AM »
Ahhh, the Z was going at about 245mm/rev hmmm could this be the problem.  If so how do I get it to follow the speed set by the 'F'
A
That would be about  correct for the example you gave, ie your revs were 120rpm and pitch was 2.1mm so that would mean 120 x 2.1 = 252mm/min
In my example above I was probably getting the terminology wrong.
Can you do a single start thread no problem?
Edit
 just read again, were you meaning 245mm/rev like you said or per min?
« Last Edit: May 08, 2009, 09:35:25 AM by Hood »
Offline Tef9
  •  89 89
« Reply #52 on: May 08, 2009, 09:35:30 AM »
Ok I will give the single start a go and post results.
A
