Hello Guest it is November 13, 2026, 05:10:55 PM
Author Topic: pokeys and G100 question  (Read 17372 times)
« on: March 30, 2009, 05:05:01 AM »
H,
I have currently a G100 set up to control my cnc, and that works just fine, but now I want to build a toolchanger that requires more io than available on the Grex.
I saw on the docs that pokey uses the same addresses as the G100. so now my question: can G100 and pokeys55 be used at the same time for digital outputs in mach? or is that going to mess up the system?
thanks,
Bram
Offline borisz
  •  220 220
    • www.poscope.com
Re: pokeys and G100 question
« Reply #1 on: March 30, 2009, 06:38:11 AM »
Does not have direct answer.
If Mach and G100 plugins will mess up, you can command PoKeys directly with PoKeys.dll
regards
Boris
« Reply #2 on: March 30, 2009, 03:11:07 PM »
hi,
thanks for your reply, i would need the pokeys mainly for outputs, is that also possible with the dll ? how do i tell mach to use that dll? or is the dll only for simulating the keystrokes?
regards,
Bram
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #3 on: March 30, 2009, 03:43:37 PM »
Please download and read PoKeys user manual from www.poscope.com
There is all described here.
Dll can be used for all PoKeys functions inputs and outputs.
regards
Boris
