Hello Guest it is October 20, 2026, 10:31:16 AM
Author Topic: Touch Probe Problem  (Read 16014 times)
Touch Probe Problem
« on: March 28, 2009, 07:25:44 AM »
I have the touch probe setup on my machine and sometimes it feeds down touches and comes up .300 and stops as it should
But sometimes it goes up 2 inches dwells and goes up again.....Why is it doing this...?
Re: Touch Probe Problem
« Reply #1 on: March 28, 2009, 05:11:46 PM »
Hi Brian,
I gave you a possible fix over on the TOC, let us know if it helps, ok?
Thanks- 8)
« Reply #2 on: March 29, 2009, 07:12:28 PM »
Thanks Dave....I looked all over there but all I could find from gary was he downloaded the screen and code seperate.....where is the code?
« Reply #3 on: March 29, 2009, 07:17:58 PM »
I believe the latest version is here in post 257 from Greg.
http://www.cnczone.com/forums/showthread.php?p=578105#post578105
He may even pop in on this thread to chime in as well-
Offline Greolt
  •  956 956
« Reply #4 on: March 29, 2009, 07:32:50 PM »
Possibly because you are starting the script when in a G91 condition.
If you are using a Z zero routine (not clear if that is what you are asking about) then the post Budman pointed to shows a script which covers for that situation.
A lot of the script examples that are around, don't.
Greg
« Reply #5 on: March 30, 2009, 12:45:09 AM »
Great....Thanks Guys...Will give it a Shot
