Hello
Guest
it is
October 20, 2026, 03:02:08 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
X Axis Problem???? Need Help Please!!!!!
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: X Axis Problem???? Need Help Please!!!!! (Read 27281 times)
lokey
60
on:
March 26, 2009, 08:32:06 PM »
Hi, I am running Mach3 with a Zenbot. I am having trouble with the X axis. During a cut the X axis shifts to the positive. The start location shows a shift to the positive of about 1/8 of an inch after the cut is complete. This problem is causing mis-alignment on all the chains being cut. Is there a solution to this problem? Thanks in advance for any any help received.
Logged
Carnoustie, Scotland
Re: X Axis Problem???? Need Help Please!!!!!
Reply #1 on:
March 26, 2009, 08:47:11 PM »
Does the X DRO have the shift in it?
Which direction are you cutting?
Logged
lokey
60
Reply #2 on:
March 26, 2009, 09:38:12 PM »
Hi, The DRO does not show the shift. Cuts are in the counter clock wise direction.
Logged
Reply #3 on:
March 27, 2009, 03:03:12 AM »
Could be a few things the most likely is you are losing steps, try reducing the accel and vel in motor tuning a bit.
Logged
lokey
60
Reply #4 on:
March 27, 2009, 05:44:46 AM »
Hi, I reduced the acceleration and the velocity . Now the circles are oval and mis-aligned.
Logged
Reply #5 on:
March 27, 2009, 04:58:37 PM »
can you give an example of what you are actually doing as your description in the first post is not very clear to me I am afraid.
Logged
lokey
60
Reply #6 on:
March 27, 2009, 10:22:16 PM »
Hi I tighten the belts and set x and y motor tuning equal to each other. It helped a lot.
Listed are measurement results:
G1 X 0.3
DRO 0.2990
dial indicator measurement = 0.294
G1 X 0.0
DRO 0.0
dial indicator measurement = 0.004
If there is any thing else I can do to zero in the Zenbot please let me know.
Logged
Reply #7 on:
March 28, 2009, 04:41:00 AM »
Sounds like you may have your steps per unit set slightly wrong,
is it steppers?
What stepping do your drives have, ie full, half, 10 micro steping?
Any reduction between motors and screws?
Pitch of screws?
Logged
lokey
60
Reply #8 on:
March 28, 2009, 07:05:09 AM »
Hi, the stepper motors are set to 1/8 th. I am using a Zenbot with kevilar drive belts.
Logged
Reply #9 on:
March 28, 2009, 07:16:40 AM »
Do the drivebelts connect to a balscrew or are they fixed directly to an axis?
If the former what is the pitch of the ballscrew and is there any reduction between motor pulley and ballscrew pulley?
If the latter what is the pitch of the belt and how many teeth are on the motors pulley?
Logged
Print
Pages:
1
2
Go Up
« previous
next »
