Hello Guest it is October 16, 2026, 12:25:59 AM
Author Topic: Need help Z axis setup???  (Read 12921 times)
Offline lokey
  •  60 60
« on: March 15, 2009, 04:32:04 PM »
Hi, I am using TurboCad, LazyCam, and Mach 3 software with a Zenbot CNC router Mill. The training videos said to setup the Z axis at the top of the slide to zero and the bottum to -4 for the software limits. When I load the G code from LazyCam to the Mach 3 software the code contains Z values greater then Zero and the software limits kick in. How do I deal with problem? One more question, What is a good feedrate for the RotoZip wood bit? Thanks in advance for any feedback received.
Re: Need help Z axis setup???
« Reply #1 on: March 15, 2009, 05:05:39 PM »
Lokey, the values that are tripping the softlimits are probably work coord. and not machine corrd. Try jogging the z down till it just touches the top of the work piece and zero the z axis work cord DRO by clicking the button just to the left of it on the program run screen.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #2 on: March 15, 2009, 05:14:20 PM »
Hi, Lokey
Also have you Set, In LazyCam the values for Tools and Cut depth's, Also need to use the "Set Layer" & "Set to All Layers" Buttons.
Chip
Offline lokey
  •  60 60
« Reply #3 on: March 15, 2009, 05:52:10 PM »
Hi, Thanks for the great feedback. It solved the problem. Now I can try my first cut.
