Hello Guest it is October 16, 2026, 12:23:57 AM
Author Topic: Motor "Sometimes" goes in Wrong Direction while Tuning  (Read 39758 times)
Re: Motor "Sometimes" goes in Wrong Direction while Tuning
« Reply #20 on: March 20, 2009, 09:05:27 AM »
Its often the case ;D
« Reply #21 on: March 20, 2009, 09:08:08 AM »
Thanks again Hood you were most helpful
do you happen to know of any wizards included in the mach software that will help me turn an inside and outside cone shape on barstock?
« Reply #22 on: March 20, 2009, 09:13:24 AM »
Is it a Lathe? as the lathe wizards have that.
 If its a mill then its not going to be easy to get a good finish unless you can chuck the stock in a collet holder, If you can then you could  use a Turn profile with a lathe tool clamped to the table or in a vice.
« Reply #23 on: March 20, 2009, 09:18:58 AM »
It is this machine on the home page of the link below it is both a lathe and a mill
http://www.shoptask.com/
I will have to look at the lathe wizards
thank you very much
