Hello Guest it is November 16, 2026, 04:59:00 PM
Author Topic: limit switches/ estop?  (Read 66787 times)
Re: limit switches/ estop?
« Reply #10 on: March 12, 2009, 05:02:42 PM »
As a different test, you might try temporarily removing the 110v AC from the NC side of your E-Stop PB.
RC
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #11 on: March 12, 2009, 05:11:28 PM »
Disconnected estop and limit switches, disabled estop input. ran jumper as suggested. Still falsely triggered limit. Though with a 2000 debounce I did get a longer delay. In ports and pins should z++, z-- & z home be enabled? It never responds if active low is selected.
OL I tried that last night and it didnt help. I even used that switch and switched to active low. Seems like it still triggered
« Reply #12 on: March 12, 2009, 06:14:43 PM »
Sounds like its your board that is creating the noise internally or picking it up anyway. If you can attach your xml I will have a look at it just in case there are any errors there but cant think how there could be but you never know :)
Maybe try some small capacitors from 11 to gnd.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #13 on: March 12, 2009, 06:43:05 PM »
Will this tell you anything?
« Reply #14 on: March 12, 2009, 06:46:18 PM »
afraid I cant download that file, what is it?
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #15 on: March 12, 2009, 06:47:45 PM »
Sorry empty file was sent, not really sure how to convert it. It is too large to post. What would the capacitors do? The board was inspected by an excellent electronics repair person who is a friend. No apparent errors and it has pased all electrical tests with no issues.
« Reply #16 on: March 12, 2009, 06:55:53 PM »
The capacitors may help to  filter any noise that is present.
To attach your xml copy it from the Mach3 folder to your desktop and then rename the copy as Fastest1.xml then the forum will accept it.
Offline Fastest1
  •  920 920
  • Houston, TX
fastest1's Xml
« Reply #17 on: March 12, 2009, 07:54:23 PM »
did it work?
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #18 on: March 12, 2009, 07:55:53 PM »
Any particular value? Is it possible the capacitor can damage the board?
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #19 on: March 12, 2009, 08:01:04 PM »
And how would I use it? Would each input get a cap or just attach all grounds to 1 cap? Or some other way?
