Hello Guest it is October 21, 2026, 10:55:13 AM
Author Topic: X axis will not change direction during cut  (Read 24197 times)
Re: X axis will not change direction during cut
« Reply #10 on: March 01, 2009, 04:18:32 PM »
That means you should set them to Active Low in the Ports and Pins Motor Output page, if I remember you had then unchecked which means active High.
