Hello Guest it is October 21, 2026, 02:53:56 PM
Author Topic: Mach3 OEM codes for Feedhold and CYcle start  (Read 37067 times)
Re: Mach3 OEM codes for Feedhold and CYcle start
« Reply #10 on: February 24, 2009, 02:30:29 PM »
To be honest I dont know, cycle start has always been the way I have done it and it is the way Mach tells you do do it with Run from Here etc
You could try the resume and see if it works as expected, if not then just change to OEM in the trigger back to 1000.
« Reply #11 on: June 03, 2010, 11:31:11 PM »
Hello, I am trying to do the same, but I have Mach 3 Ver 1.83, I need to set in OEM TRIGGERS
Cycle Start, Free Hold and Single Blk Mode
Rene
« Reply #12 on: June 04, 2010, 01:58:02 AM »
Rene
Sorry not really clear what your problem is.
« Reply #13 on: June 04, 2010, 10:44:18 AM »
Sorry my bad question, was too late in night.......
I want to use OEM TRIGGERS  for Cycle Start, Resume, Single Blk mode.
They will be activated by optical switches and rotary shutter in a embroidery machine
shaft.
Also I need to use OEM TRIGGERS for Free Hold, when thread breaks.
I read about configurate this, no problem in this part
I have excel code table for OEM List Alfa 6, that you posted here , thanks
I have an old Mach 3 V1.183.027. I need to know what codes use for this
old version, or if that than I read here are useful for me.
I will thanks if you can help me codes for olv versions of Mach are.
Regards
Rene
« Reply #14 on: June 04, 2010, 12:55:18 PM »
That was Brett that did the Alpha list :)
OEM codes will be the same in the old versions as they are up to this point in time but in future versions it may change.
« Reply #15 on: June 04, 2010, 02:52:47 PM »
Thanks Hood
Regards
Rene
« Reply #16 on: October 06, 2013, 09:14:07 AM »
thank's for this is very helpfull
« Last Edit: October 06, 2013, 09:18:03 AM by simind »
