Hello Guest it is October 21, 2026, 07:22:25 AM
Author Topic: mpg counts/unit selection.  (Read 11679 times)
« on: February 21, 2009, 12:56:12 AM »
Hello All,
I would like to know if it is possible to set up my diy MPG so that I can change the counts/unit value via a switch.  Currently all I have hooked up is the encoder and one switch, which toggles between the different axis. I am hoping to add a knob w/ 3 positions which select 3 different counts/unit of movement.  If any one has any experience with this please share with me your thoughts.
Thank you in advance,
Jose.
Re: mpg counts/unit selection.
« Reply #1 on: February 21, 2009, 04:35:44 AM »
I have three switches on my lathe panel, one switches  full jog mode another multi step mode and the third will toggle the units for the multistep.
