Hello Guest it is November 16, 2026, 04:59:05 PM
Author Topic: output for smooth stepper  (Read 70296 times)
Re: output for smooth stepper
« Reply #10 on: February 18, 2009, 03:01:56 PM »
I did set up a new profile for the SS and my setting are there Including the M10 and M11 in the Macro folder, I did not write these marcos they were already there..
« Reply #11 on: February 18, 2009, 03:05:54 PM »
yes but are the contents the same between the PP one and the SS one?
« Reply #12 on: February 18, 2009, 03:08:36 PM »
the contents in the folder are the same but when I go to click on the M10 or M11 file windows dose not now what program to use to open It.
« Reply #13 on: February 18, 2009, 03:12:14 PM »
Thanks for the post Ray,,
So you think the board is ignoring my M11 P4, M11 P9, output commands?,, could it be the bleed down resistors?
thanks
I have no idea what M10 and M11 do.  But why aren't you using move commands (M0/M1/M2/M3)??  Or simply jogging?
« Reply #14 on: February 18, 2009, 03:12:41 PM »
Open it from Mach, operator menu then VB Editor. Then use File, Open and then browse to the macro you want to look at or edit.
« Reply #15 on: February 18, 2009, 03:28:53 PM »
OK I looked at both SS profile and Mill profile M10 and M11 commands in the VB editor,   and they are exactly the same  in both profiles, I dont understand how they work but they are the same
josh
« Reply #16 on: February 18, 2009, 03:30:31 PM »
what are you using the outputs for and what outputs?
Might want to copy and paste the M10 from the PP profile into the SS profile just in case there is a difference.
« Reply #17 on: February 18, 2009, 03:41:10 PM »
Output #4 on pin 7 turns machine on, output #9 on pin14 turns cooling water on output# 5 on pin1 ejects a part,, there are a lot of things going on in a short amount of time
M3
X -00.000 Y00.00000 Z00.00000 F550.00
M11 P4
G1 X -00.145 Y00.00000 Z00.00000 F014.0
M11 P9
G1 X -05.0030 Y00.00000 Z00.00000 F078.0
M10 P4
M10 P4
X -06.000 Y00.00000 Z00.00000 F800.00
G4 P1.0
X -06.100 Y00.00000 Z00.00000 F7800.00
M11 P7
M11 P5
X -06.200 Y00.00000 Z00.00000 F800.00
M10 P9
G4 P00.2
M10 P7
X -06.250 Y00.00000 Z00.00000 F800.00
M6
G4 P0.5
X -00.000 Y00.00000 Z00.00000 F800.00
M30
M30
josh
« Reply #18 on: February 18, 2009, 04:02:57 PM »
I checked pin 1 without the c11 board hooked up and i did not see any voltage, I should have seen 5 v dc with my program running,, soo it must me in the SS ??
« Reply #19 on: February 18, 2009, 04:03:59 PM »
Ah ok did  Brian write that macro specifically for you, the P values are for the outputs you want to use?
