Hello Guest it is October 20, 2026, 03:09:43 PM
Author Topic: got the 4th axis running  (Read 28704 times)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: got the 4th axis running
« Reply #10 on: February 18, 2009, 08:53:10 PM »
Hi, Josh
The use diameter for feedrate uses the, Setting's page, Set A rot. Dia. "value" to calculate the F speed in relationship to the part Diameter.
360 rollover, When the A axis hit's 360 it reverts to 0 deg. value, With out it checked axis will continue to count up and if you issue a A0 the axis will reverse direction.
Play with these settings and G-code to see how thay respond.
Chip
Offline josh
  •  101 101
« Reply #11 on: February 18, 2009, 10:40:55 PM »
chip
let me try this question 1st (The use diameter for feedrate uses the, Setting's page, Set A rot. Dia. "value" to calculate the F speed in relationship to the part Diameter.)
so let say I have a stock of 2 inches  and I am doing some milling around this stock does that mean  on the settings page go to rotation diameter, I would input 2 inches.
does that sound correct.
Offline Chip
  •  2,055 2,055
« Reply #12 on: February 19, 2009, 10:16:30 AM »
Hi, Josh
Yes, The feed rate will be based on the stock diameter, As your finding, A axis setting will need to be changed depending on the job setup.
Chip
