Hello
Guest
it is
September 29, 2026, 08:31:02 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
FAQs
milling a part
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: milling a part (Read 9435 times)
artrans
13
milling a part
on:
February 04, 2009, 03:33:34 PM »
i want to mill a connecting rod out of 1/4 plate alum to start so lets say I have a piece of plate 4 inches wide 10 inches long a mount that in the mill do I need a hole in the center of the connecting rod to hold it to the machine or what happens when it is cut out.
Tweakie.CNC
9,374
Super Kitty
Re: milling a part
Reply #1 on:
February 16, 2009, 07:02:11 AM »
Usually the two holes at either end of the con rod are cnc drilled/milled and these are used to secure it to a sacrifical plate (wood perhaps) then it is profile cut.
Hope this helps.
Print
Pages:
1
Go Up
« previous
next »
