Hello Guest it is September 29, 2026, 08:32:32 AM
Author Topic: milling a part  (Read 9437 times)
milling a part
« on: February 04, 2009, 03:33:34 PM »
i want to mill a connecting rod out of 1/4 plate alum to start so lets say I have a piece of plate 4 inches wide 10 inches long a mount that in the mill do I need a hole in the center of the connecting rod to hold it to the machine or what happens when it is cut out. ???
  •  9,374 9,374
Re: milling a part
« Reply #1 on: February 16, 2009, 07:02:11 AM »
Usually the two holes at either end of the con rod are cnc drilled/milled and these are used to secure it to a sacrifical plate (wood perhaps) then it is profile cut.
Hope this helps.
