Hello Guest it is September 29, 2026, 04:38:06 AM
Author Topic: MAXNC15  (Read 12667 times)
MAXNC15
« on: February 04, 2009, 02:06:01 PM »
OK NEW PROBLEM BUT i AM GETTING CLOSER THANKS TO SOME OF YOU  i HAVE A MAXNC15 WITH THERE SO CALLED NEW SOFTWARE WHICH LOOKS LIKE MACH3 i DRAW A PART IN CADSTD PRO SEND IT TO LAZYCAM LOAD TO MACH3 i GET GCODE THAT'S A BIG STEP BUT NOW i TRY TO GET IT INTO MAXNC VERISON OF MACH3 AND i CANNOT ANY BODY HAVE A ANSWER FOR THAT THANK YOU ART
ANYBODY FROM NEW YORK THAT CAN DO A HANDS ON THAT WOULD BE A DREAM COME TRUE FOR ME NIGHTMARE FOR YOU
Re: MAXNC15
« Reply #1 on: February 04, 2009, 02:35:19 PM »
He is some gcode i got for a connecting rod I am try to make can some please teach me something here 1st LINE IS THAT THE SIZE OF THE RAW MATRIAL NEXT F WHERE DOES THE F COME IN OTHER WHAT I THINK IT MEANS AND IAM F%^$$#KED but really waht do they mean
what i no xyz table got that, m/ motor on off,s/speed now m5m30 whats that and with the g code posted I still have to set the depth or z
do I have anyof this right or should I throw in the towel. This make one fell stupid I can rebuild automatic transmission computer controled all day this is make my hair hurt but I will not give up although i have come close. thanks for any help
G90G80G49
G0 Z1.0000
G90.1
S1000
G0 Z1.0000
G0 X3.0000 Y1.5000
M3
F1.000G1 Z0.0000
F1.000G1 X3.0000 Y3.0000
G1 X5.0000 Y3.0000
G1 X5.0000 Y1.5000
G1 X3.0000 Y1.5000
G0 Z1.0000
G0 X3.3269 Y2.2500
F1.000 G1 Z0.0000
G2 X3.3269 Y2.2500 I4.0000 j2.2500
G0 Z1.0000
G0 X3.5000 Y3.2500
F1.000G1 Z0.0000
F1.000G1 X4.5000 Y3.2500
G1 X4.1250 Y8.7500
G1 X3.8750 Y8.7500
G1 X3.5000 Y3.2500
G0 Z1.0000
G0 X3.2387 Y3.0000
F1.000G1 Z0.0000
F1.000G1 X3.6911 Y9.0000
G0 Z1.0000
G0 X3.8288 Y9.0000
F1.000G1 Z0.0000
F1.000G1 X3.8681 Y9.0000
G0 Z1.0000
G0 X3.5000 Y9.0000
F1.000G1 Z0.0000
F1.000G1 X4.5000 Y9.0000
G1 X4.5000 Y10.0000
G1 X3.5000 Y10.0000
G1 X3.5000 Y9.0000
G0 Z1.0000
G0 X3.7205 Y9.5000
F1.000 G1 Z0.0000
G2 X3.7205 Y9.5000 I4.0000 j9.5000
G0 Z1.0000
G0 X4.7139 Y3.0000
F1.000G1 Z0.0000
F1.000G1 X4.3008 Y9.0000
M5
G0 Z1.0000
G0 X0 Y0
M5M30
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: MAXNC15
« Reply #2 on: February 04, 2009, 10:21:03 PM »
Hi, Artrans
Don't be in a hurry hear, You need to do some research on G-code, Lot's of info hear, Top of this page under Support, Documtation section you'll find Mach3 manuals that will give you lot's of info.
Your g-code will cut your rod in 3 part's as it is now, You need edit the dxf and remove some of the lines, Look at the second picture hear, This is how the outer part of the rod should be drawn.
Don't get frustrated, It took you awhile to learn the in's and out's on transmissions also, I'd Guess.
Chip
Re: MAXNC15
« Reply #3 on: February 05, 2009, 07:19:23 AM »
thanks chip for the info and your time
