Hello Guest it is October 21, 2026, 04:33:28 PM
Author Topic: "Graphics" run in preview  (Read 28665 times)
Offline TDAY
  •  165 165
    • Home CNC Stuff
« on: January 30, 2009, 09:28:14 AM »
Hello Ron,
 Wondering if a graphics or Dry Run can be added to the preview of wizards? So one can watch program run in the Preview,before posting Gcode, as this would help much if a program has a few wizards. Also it would run offline and NOT move the actual machine.
Troy
"I try to put forth the effort,before asking a dum question"
http://homecncstuff.elementfx.com
Re: "Graphics" run in preview
« Reply #1 on: February 01, 2009, 10:35:15 AM »
In the latest version I have added a gcode window to the preview screen, so now you can see both the code and the path. When I want to watch it run through the code, like when Im testing the order of cuts, I just scroll down the code window, that highlights the tool path with the current line. It seems to me that does the equivalent of the preview.
The preview button on the main screen is a not a VB function its coded into Mach. I cannot get that from a wizard.
