Hello Guest it is October 25, 2026, 01:11:21 PM
Author Topic: Front & rear toolpost in Turn 42.020  (Read 32000 times)
Re: Front & rear toolpost in Turn 42.020
« Reply #10 on: August 28, 2009, 12:29:26 PM »
Well all I can say is I am glad my workshop has no room ;D
Offline Kola
  •  10 10
« Reply #11 on: January 07, 2010, 04:13:50 PM »
Hi Im Kola from Hungary - Magyarul szeretnék kérdezni a mellső és ahátsó késtartó beállításiról ha van itt egy honfitárs?
« Reply #12 on: January 07, 2010, 04:21:55 PM »
Welcome to the forum  :)
You should maybe start a new post to ask if you have any fellow countrymen in the title, that way they will see it instead of it being at the bottom of another thread that has no reference to the question.
Offline Kola
  •  10 10
« Reply #13 on: January 07, 2010, 04:51:37 PM »
« Reply #14 on: January 07, 2010, 04:56:55 PM »
Nice wee lathe :) What make is it, looks sturdy.
Offline Kola
  •  10 10
« Reply #15 on: January 07, 2010, 05:12:18 PM »
I don't know how to setting the front  & rear toolpost .
If i set rear tool then the system is down!!!
« Reply #16 on: January 07, 2010, 05:34:00 PM »
You can only set up all tools for either front or all for rear, you cant use both at the moment. Turn will be getting worked on at some point and that is one of the things that wiill be getting sorted.
Offline Kola
  •  10 10
« Reply #17 on: January 08, 2010, 02:40:46 PM »
Hi, you can not setup the rear tool holder system!
Today I tried so that the rear tool holder, Front configured and saved to the table tool, programming should be a negative sign on the x-axis coordinates, and so works well
  Welcome Kola
Offline Kola
  •  10 10
Magyar kérdések a Mach3Turn programról magyar válaszokkal
« Reply #18 on: January 08, 2010, 02:51:22 PM »
Üdvözletem!
Azt  szeretném kérdezni van-e itt valaki akinek sikerült a hátsó késtartó beállítása úgy hogy lehessen váltani menet közben az elsőre és vissza a g kódban programozva!
 üdv Kola
Offline Kola
  •  10 10
« Reply #19 on: January 24, 2010, 12:18:49 PM »
One application of the front and rear tool problem http://www.cnctar.hunbay.com/KoLa/Vide%F3/Egy%20k%E9s.avi
