Hello Guest it is November 13, 2026, 01:00:59 PM
Author Topic: stop waiting G4  (Read 43878 times)
Offline klmark
  •  107 107
Re: stop waiting G4
« Reply #10 on: March 11, 2007, 09:34:27 AM »
hi guys
how would i get contact with the user name axilleas he talk about dwell features that i realy need and would like but i need more help i am new to mach 3 Thank you ley me know
Re: stop waiting G4
« Reply #11 on: March 12, 2007, 07:13:44 AM »
just pm me :)
Offline klmark
  •  107 107
Re: stop waiting G4
« Reply #12 on: March 12, 2007, 08:47:31 AM »
Hi axilleas
I am Mark   I am new to a mack licence user on the dwell post you guys talk what i want on my cnc machine I use a flam cutter and plan to add on a plasma but a the dwell feature i want z axis to plunge down preheat until i comment the machine to start the torch and start moving the x y axis on the toolpath i know it can be done because you guys talk about it in the forums so Please let me know how to do it it would be greatly appreciate
Re: stop waiting G4
« Reply #13 on: March 12, 2007, 01:03:24 PM »
Simplest way would be to put M1 in the code where you want it to stop, when its ready to move again all you do is press start, If you knew the exact time you wanted a pause you could put G4 P** (** being time in seconds) and after that time had elapsed it would continue.
Offline klmark
  •  107 107
Re: stop waiting G4
« Reply #14 on: March 12, 2007, 01:12:09 PM »
would i have to add M1 Manuel on every plunge If that is so there has to be a better way
Re: stop waiting G4
« Reply #15 on: March 12, 2007, 01:19:32 PM »
Ho many plunges/pauses would you be looking at in a typical programme?
How do you write the programme, if its with CAM it may be possible to get the CAM to add it automatically.
Offline klmark
  •  107 107
Re: stop waiting G4
« Reply #16 on: March 12, 2007, 01:46:32 PM »
on a flamcutting a guy dose quiet a bit of plunging as far as the cam i plan to use lazycam i appreciate our feedback Thank you
Re: stop waiting G4
« Reply #17 on: March 12, 2007, 03:59:40 PM »
not sure if it would be possible or even practical but you may be able to use the macro pump. Adding a bit of code to pause or M1 when a given situation is seen shouldnt be that hard to do. I am fairly new to VB so maybe I am just talking through my arse.
Offline klmark
  •  107 107
Re: stop waiting G4
« Reply #18 on: March 12, 2007, 04:43:17 PM »
I would not mined if i had to push the start buttom on every plunge
Re: stop waiting G4
« Reply #19 on: March 12, 2007, 04:47:28 PM »
If you will be present each time you plunge could you not then just press the feedhold button then when you want to go again you could press start?
