Hello Guest it is November 11, 2026, 05:53:22 AM
Author Topic: SS with Polish translated Mach  (Read 13997 times)
« on: January 15, 2009, 09:42:42 AM »
Hi to everybody,
I have a problem with SS with Mach3 Polish translated version.
The problem is that the plugind does not appear in the Translated version.  :-\
I hope somebody knows a solution to solve this.
Any help appritiated.
I attached some pictures below to let you see the problem.
The plugin menu seems empty.   :o
Re: SS with Polish translated Mach
« Reply #1 on: January 15, 2009, 03:05:19 PM »
If you do translate the Menu-Dialog "PlugInControl" the installed Plugins will not
be visible!
Ive had the same problem with the German-translated version...
Best regards,
Wolfram
« Reply #2 on: January 15, 2009, 03:45:16 PM »
Hello,
Thank you for sharing me this info.
And did you find any solution yet to solve the problem?
Or do you think that there is no solution for this?  :-\
Thanks in advance.
Best regards,
                 Balazs
