Hello Guest it is October 22, 2026, 04:36:06 PM
Author Topic: Compatability Question  (Read 40804 times)
Re: Compatability Question
« Reply #10 on: January 15, 2009, 03:48:05 PM »
It could be done but wont be just a straight swap, for a start your motors have resolvers and tachs which suggest that the drives (Amps ) will be analogue, that is no use for Mach. Rutex do a Step/Dir to analogue converter but so far I have not seen anyone that has used one. DSPMC do a motion controller that can control analogue drives and it seeminly works well but it is  fairly expensive. You will also have a lot of figuring out to do but as has been said you could convert but not just a case of plugging it in.
Offline HGC
  •  12 12
« Reply #11 on: January 16, 2009, 07:53:01 AM »
Sounds like my retrofit for my retrofit will cost more than I have in the whole lathe. Crap.
« Reply #12 on: January 16, 2009, 08:10:54 AM »
What current and voltage are your motors?
Offline HGC
  •  12 12
« Reply #13 on: January 16, 2009, 09:00:25 AM »
Pitman 19.1 VDC
« Reply #14 on: January 16, 2009, 09:08:51 AM »
that seems very low, was expecting 180 or 190V, what is the current of them? Or do you have a model number.
Offline HGC
  •  12 12
« Reply #15 on: January 16, 2009, 09:32:57 AM »
You are talking about the axis motors right?
« Reply #16 on: January 16, 2009, 09:39:22 AM »
yes, they are servo motors arent they?
Offline HGC
  •  12 12
« Reply #17 on: January 16, 2009, 09:57:45 AM »
This is the X axis motor. bad photo.
« Reply #18 on: January 16, 2009, 10:22:18 AM »
certainly look like dc servos, bit hard to tell from the pic, are there just two heavy wires to the motor itself? Any details or model numbers on the motor? What size is the lathe as the resolver size makes it look like the motor is fairly small.
Offline HGC
  •  12 12
« Reply #19 on: January 16, 2009, 10:55:44 AM »
Yes there are only 2 big wires. The motors are Pittman #13204C187 19.1 VDC. Attached is a photo of the lathe. It is a small one. Only 17" or so between centers.
