Hello Guest it is November 21, 2026, 11:11:36 AM
Author Topic: Need HELP with Mach3 Setup  (Read 46978 times)
Offline johnv
  •  43 43
« on: January 13, 2009, 11:58:51 AM »
I built a cnc router. The Control console uses (3) KL-4030 Drivers to drive (3) KL23H286-20-8B motors, a CNC4PC C10 Parallel Port Interface card and using Mach3 software. I built a 555 square wave generator  to test out the wiring.  I insert the square wave (800Hz @ 5v p-p) onto pin 2; 4; and 6 and all motors run fine in both directions. My problem is getting Mach3 to do the same. I watched the configuration video, followed all instructions, and all seems to be in order. When I go to Motor Tuning, I choose axis, insert proper step value ( even improper step value) play with Accel & Velocity, save axis settings then press up or down keyboard key. Sometimes I get motion sometimes I don't. I can't get continuous running. Same on all axis'.  Tried using Mach3 from 2 different computers to no avail. Scope shows input to x-step (pin 2) about 6us pulse 5vp-p (555 is much longer pulse). I know it must be a setup fluke but I can't find it. I took some pics of my setup. I'll try to post them if I can. If not, you can PM me, I'll be happy to forward you a copy. It could help to clarify things. Any and all help would be appreciated. Thanks gentlemen.
Offline zarzul
  •  233 233
  • Wyoming, USA
Re: Need HELP with Mach3 Setup
« Reply #1 on: January 13, 2009, 12:06:45 PM »
What are you using for step value?
« Reply #2 on: January 13, 2009, 12:32:09 PM »
Have you run the Drive Test to see if your pulse is clean? Have you tried with a pulse width of 5?
Offline johnv
  •  43 43
« Reply #3 on: January 13, 2009, 01:14:56 PM »
I'm using 1/2 microsteps and 2.7A
Offline johnv
  •  43 43
« Reply #4 on: January 13, 2009, 01:16:30 PM »
Tried both. Pulse is clean and I'm presently set to 5uSecond increase.
« Reply #5 on: January 13, 2009, 01:30:59 PM »
 Have you put the scope direct to the PP?
Offline johnv
  •  43 43
« Reply #6 on: January 13, 2009, 01:50:37 PM »
I don't know what you mean by the PP.
« Reply #7 on: January 13, 2009, 02:34:52 PM »
PP is Parallel Port, ie seeing what the pulse out the port is before it gets to the breakout.
Offline johnv
  •  43 43
« Reply #8 on: January 13, 2009, 03:29:40 PM »
Good thought!  Checked it out. Exact same pulse with no distortion. Thanks for hanging in there with me.
« Reply #9 on: January 13, 2009, 04:29:34 PM »
Ok dont think your drives should need it but might we worth trying Sherline mode.
