Hello
Guest
it is
November 11, 2026, 05:18:58 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
SmoothStepper USB
(Moderator:
Warp9TD
SS: Motors won't turn yet
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: SS: Motors won't turn yet (Read 31344 times)
Carnoustie, Scotland
Re: SS: Motors won't turn yet
Reply #10 on:
January 29, 2009, 03:22:08 AM »
Do you have an E-Stop button?
bfairey
40
Reply #11 on:
January 29, 2009, 05:58:01 AM »
You mean one of those red mushrooms headed switches, yes , but I dont know what to connect it to.
Brian.
Reply #12 on:
January 30, 2009, 03:28:47 AM »
You need to connect it to an Input pin and probably ground the other side but that may depend on your breakout board.
If you dont have it connected at the moment you can just set Mach to Port2 Pin 10 and set the active state of that pin to Make Mach think the switch is closed. If you are already use port2 pin 10 then choose another pin that you are not using.
Print
Pages:
1
2
Go Up
« previous
next »
