Hello Guest it is November 08, 2026, 04:11:29 AM
Author Topic: Another new screen  (Read 173851 times)
Re: Another new screen
« Reply #20 on: January 07, 2009, 09:01:09 PM »
Figuring out where to put everything sure takes a long time.  :( I've got this so far. Instead of LEDs, the buttons will change color when active. (Axis Zero, Run, etc..) I played around with the button face being a two state LED, and using a transparent button over the top. It works, but you seem to lose the "button push". I'll sacrifice that for the coolness of two color buttons. :)
With any luck, I'll have something for you guys to play with soon. It'll be far from finished, but good enough to run code. maybe. :)
« Reply #21 on: January 07, 2009, 09:17:26 PM »
NICE Gerry,
  How bout a little screen shot of a button ON beside one that is OFF.
Like to see the difference.
Overanxious.....I know,
RC
« Reply #22 on: January 08, 2009, 06:41:45 AM »
When I get home tonight I'll post one.
« Reply #23 on: January 08, 2009, 07:36:59 AM »
 :) Thanks Ger  :)
RC 8)
« Reply #24 on: January 08, 2009, 06:51:06 PM »
How about this?
« Reply #25 on: January 08, 2009, 07:10:31 PM »
Nice.....REAL nice.
Thanks Ger,
RC
« Last Edit: January 08, 2009, 07:13:52 PM by Overloaded »
« Reply #26 on: January 10, 2009, 09:04:56 AM »
Here's an update. Forgot to add an Error Line, so I used the mode line and added a new smaller mode line, and downsized the code window a hair. This image shows the X axis ref'd, and the Start button pushed, with code running. When stopped, the Start button goes back to blue.
I have to shrink the start buttons a bit. If you look closely, you can see the square corner of the button image overlapping the round corner of the border. What a pita. :( They don't shrink well in Photoshop, so I'll have to make new ones. At least I only have to make one, then copy/paste and edit the text.
I might have these two screens done enough to run code with most of the functions working in a week or so. Then I'll upload it so you can play with it. It looks really cool when running. Blows away the last screen I made.
« Last Edit: January 10, 2009, 09:09:17 AM by ger21 »
« Reply #27 on: January 10, 2009, 10:17:14 AM »
Gerry,
I see you have retained the scale buttons. I have always wondered who uses those. I can't see how they would be of much use on a mill. Do you perhaps run a plasma cutter?
Andy
« Reply #28 on: January 10, 2009, 10:36:46 AM »
I don't even have a machine. :) I've been working on a router on and off for about 5 years, though. It's been almost done for over a year. And I've been designing a better one for the last year too. As soon as the first one is done, construction of the second one will start. Maybe. ;)
I'm making this screen as a testbed for another screen that I'll do for the newer router. I'm basically duplicating the simple screen that I made a few months ago. But since I have room, I figured I'd throw in most of what the standard screens have, to make it more useable to more people. But a lot more organized and easier to read.
To answer your question, I doubt that I'd ever use the scale DRO's. But since there's room, I figured why not. :)
« Reply #29 on: January 10, 2009, 12:21:35 PM »
I wonder how many things you'll change after you really start digging into your machine.  ;)
I've made so many changes to my screenset after I started doing certain things repeatedly and eliminating others that don't ever get used or at least moving them to another screen in the set that I "thought" were going to be used.
It looks really nice so far.
