Hello Guest it is October 24, 2026, 04:34:07 PM
Recent Posts
Pages: « 1 2 3 4 5 6 7 8 9 10 »
61
Correct, the other plug has the position sensor, which is plugged in and powered on. My system uses Ethernet Smooth Stepper (ESS) and Avid CNC's proprietary footprint 556 type controller called a CRP5056.
62
PoKeys / Re: connect 24VDC Quad (4 Channel) Relay Module to Pokeys57CNC
« Last post by Toner on September 22, 2026, 12:56:09 PM »
Update: Getting answers from PoLabs - Slovenia . "The OC outputs can be used to drive various external peripherals and such relay board is indeed one of them.
For a basic active high signal inputs, you can connect OC+ to the power supply for relay board logic, OC- to relay board input."
63
Cabinet Wizard v1.02 Update
Corrected Drawer Runner hole coordinate orientation.
Added 3 save/load setting presets for Shelf, Drawer and Hinge operations.
Expanded built-in Help.
Minor usability improvements.
Please use v1.02 for new installations.
64
Mach4 General Discussion / Re: Need Help Configuring Mach 4 on OTK Retrofit on AVID/ESS
« Last post by Bill_O on September 22, 2026, 08:00:12 AM »
Did you check the other plug?
It has the limit switch and, I believe of the top of my head, the power for the unit.
What motion controller and breakout board are you using?
65
Thanks for the reply. If you are talking about the 6-pin connector that goes to the cutting head, I checked continuity on all of the conductors prior to installation. I'm almost positive that I'm just missing a pin setting or something in Mach 4.
66
« Last post by Bill_O on September 22, 2026, 07:03:49 AM »
I use the Ecocam modules also.
Check the wires in the plugs.
They can be a little touchy about how far in they are.
67
Mach4 General Discussion / Re: Mach4 PCID - Seemingly Random Changes
« Last post by metaphysic on September 22, 2026, 03:41:06 AM »
I’d start by checking whether the PCID changes correlate with Windows updates, driver changes, or Mach4 configuration changes. Keeping a record of the PCID before and after each update could help identify what is triggering it. A stable network setup may also be preferable to changing the OS, since Mach4 licensing can depend on system-specific information.
68
Excellent work Kiefer.
Cabinet Wizard v1.01
Updated installation with corrected licensing path for future FULL-version activation.
No changes to the Cabinet Wizard functions or FREE-version limits.
Please use v1.01 for new installations.
70
I would like to introduce Cabinet Wizard, a Mach3 Wizard I developed for CNC machining of cabinet side panels.
The idea is to generate the required G-code directly in Mach3 without using separate CAD/CAM software for common cabinet operations.
Cabinet Wizard currently includes:
Shelf hole drilling
Drawer runner drilling
Blum Tandem 560H and 563H predefined runner patterns
Custom drawer runner patterns
Hinge mounting hole drilling
Rear slot/groove milling
Multiple operations can be combined into a single G-code program
Automatic checks for dimensions, hole positions and possible machining conflicts
The FREE version is fully functional, with the following limits:
Shelf drilling: maximum 8 generated holes
Drawer runner drilling: maximum 8 generated holes
Hinge drilling: maximum 4 generated holes
Slot milling: unlimited
Installation is simple: extract the Cabinet Wizard folder into:
C:\Mach3\Addons\
Wizard -> Pick Wizard -> Cabinet Wizard
I have been using Mach3 for many years and developed this Wizard around the way I actually work with CNC cabinet parts. I would appreciate feedback from other Mach3 users, particularly if you find any problems or have questions about using it.
