Mach Discussion => General Mach Discussion => Topic started by: lsykes on December 15, 2008, 03:59:36 PM
First off, all my axis buttons are red. (I think that I pushed ref all home button at the wrong time during my long and ongoing desparing setup experience.) Also when I try to use the write wizard I get a red abnormal condition button flashing and have to exit Mach 3 then reenter to put the red LED light out. HELP Please!!
If you have not referenced the machine the LEDs at the side of each axis DRO will be Red. If you have home switches then do a Ref All and it will home your machine and you will be referenced and the LEDs will be Green. If you dont have Home switches then make sure you do not have them enabled in Ports and Pin Inputs, you can then press the Ref All and the LEDs will turn green.
The abnormal condition LEDÂ can be a pain or a godsend, depends on the way you look at it, for me its a pain and I did away with it on my screen. Anyway if you click on the Abnormal button it will tell you why its an abnormal condition and if its not an abnormal condition then you can double click and choose ok and it will go out and set that state as a normal condition.
