Mach Discussion => General Mach Discussion => Topic started by: jimpinder on December 10, 2008, 04:40:25 AM
I have just moved my touch screen into the workshop and linked it up to Mach 3 - it's great.
I was altering some of the screens - basically to give bigger buttons for my numb fingers, and add jog buttons to the basic set and lset screens. I had a niggling thing happen - when I made an alteration to an icon, say an OEM code, or a picture size, when I pressed OK, the image jumped, usually about 2.5 inches to the left, sometimes, down the screen, and I had to search for it, then bring it back to it's correct position.
What am I doing wrong, or not doing ??? :-[
Actually from what I have found, Jim, you're not doing anything wrong at all, it's a weird occurance in Screen 4.
I have had things like this happen and sometimes they don't and I always use the same screen size so it's not a pixel issue.
Possibly someone else will have some info for you.
I just grin and bear it as it's a free program and works fairly well and is a godsend at times- ;D
You need to open the screen set that you are working on in the highest resolution that will fit your screen with out scroll bars up/down or left/right.
Not sure why but it fixed the same thing for me.
Dennis
I've tried that before as well and it doesn't seem to work on all systems :-\
Another thing keep the bitmaps off as much as possible that helps to, at least on my computer.
Dennis
Thanks for all the suggestions - I will persevere.
