Mach Discussion => General Mach Discussion => Topic started by: mailman on November 28, 2008, 06:02:48 PM
I am going to be using a new computer in my shop, so I need to install Mach 3 onto it. Can I use my same licensee key for the new computer, if so how do I install, I can't remember how I installed on my old one. My license is only two months old. Thanks, Mailman
Yes you can, just look in your Mach3 folder and you should see a file called Mach1Lic.dat copy that into your new computers Mach3 folder and next time you start Mach it should be registered.
If you already have a machine running on your old computer you can copy the xml into the new one and all of your settings will be transfereed.
Thanks ,I will give it a shot. Mailman
also check a file mach3mill.xlm has your settings transfer that over too
Thanks again, Mailman
