Mach Discussion => General Mach Discussion => Topic started by: docltf on November 11, 2008, 12:56:30 PM
using mach3 ver 2.02 and ver 3.042.016 -- using no CV and no backlash!
below a code snippet. -- mach3 adds a move between the lines of code before execution.
g00 x-1.9375 y0 a0
g01 z-.100 f5
(then Aaxis makes a move 0.050)
g01 x-.0625 y.125 a90 f7.0
g02 x-.0625 y-.125 r.125
( then A makes a move 90.2167)
g01 x-1.9375 y0 a180
( then A makes a move 180.050)
g01 x-.0625 y.125 a270
( then A makes a move 270.2167)
g01 x-1.9375 y0 a360
the Axis is suppose to move from 0 to 90 not 0 to 0.050 then to 90 .
it is adding a extra move before it executes a line of code that includes the 4th axis
bill
Are you using backlash compensation? That will add moves.
Does it act the same with both versions? Can't tell you anything about 2.02 ( is this before 2.63 even?)
What code do you have before the first goo?
Also did you write the code or did it come from a wizard?
Hi ,Rich
i got it under control but it is still not clean ,just a slight move. had to set shuttle speed to the bar bone and open and close mach a few times so it would catch.i never noticed it running
small dia parts . with a 18 inch dia part it is a big problem. well back to the grind,thanks.
bill
