Mach Discussion => General Mach Discussion => Topic started by: plasmaman on October 29, 2008, 07:59:46 PM
Hello,
I have spent several days trying to figure out how to use Mach3 in my plasma setup. I want to use 3 phase motors for x and y axis as well as for torch height.
I learnt that I could use one PWM output with MACH3 to drive one 3 phase motor by means of VFD. But... could I drive three 3 phase motors by means of three VFD's? Or at least two? :-)
Any help is highly appreciated, as I am in doubt should I pursue this kind of solution.
You need either steppers or servos for your axis. The PWM is meant for spindle control and cant be controlled for position.
