Mach Discussion => General Mach Discussion => Topic started by: tech.tron on October 26, 2008, 08:52:32 PM
I'm here because could not achieve a stable pulse rate in MACH3.
Intel D101GGC Mainboard with 512Mb DDR400 Ram, 3GHz core Duo CPU.
Pulse rate in both Compatibility test and in Diagnostics varied considerably.
Tried all the XP Optimisation suggestions from the ARTSOFT document including running as a 'Standard PC' - no improvement.
Eventually found post(s) relating to C1E and to RMClock (How_to_run_Mach3_on_a_laptop)
Using the maximal performace mode and setting C1E off using RMClock appear to have resolved the issues.
1. Is there a way to set C1E off permanently so RMClock does not have to be run on start up every time?
2. Is the compatibility test always run at ta fixed 25kHz? - I guess so as it does not change even when the pulse rate is changed in MACH3.
3. Running MACH3 Ver 2.63. Latest manual is for Ver 1.84. Is there a newer manual or an update or anything (presumably there have been changes since Ver 1.84)
Sorry cant answer your first question as I have never had to look at these settings. For your second then yes 25KHz is the speed driver test runs at and lastly your third question. No updated docs at the moment but there is a new revision on its way, how quickly it will come out I dont know as things in Mach are always changing so it will probably be outdated the day after its released ;D
Thanks for your response.
Is there any way to download the Tutorial Videos so they can be reviewed again offline?
yep you can get them on the ftp site, right click and save as.
Sorry I'm new here and just don't seem to be able to find this stuff at all. Call me thick but have not been able to find any reference to these files or an FTP site.
Do you have a link or URL for the FTP site?
ftp://ftp.machsupport.com/Videos/
Got them - Thanks again!
Always remember to check your RAM bus speed and match it to the processor. Does not help to have a 800MHZ frontbus that has to be slowed down to keep up with slow ram.
You have DDR400? On a 3GHZ dual core, your frontbus must be 800MHZ to 1GHZ. At least trade that ram for 667
Whacko
Thanks for the suggestion.
The machine, while basically unused and therefore 'new', is actually 2 years old. Only Ram speeds supported on the mainboard are 400 and 533.
Having turned off the power saving and CPU speed changing 'sophistication' the wave form now matches the 'good waveform' shown in the 'install_config.swf video.
