Mach Discussion => General Mach Discussion => Topic started by: hoop on October 22, 2008, 11:10:58 PM
After a tool change, the speeds specified by the Gcode seem to be ignored and the speed in "motor tuning" is used. Before the tool change everything works as planned. I am using the latest legacy mach 3 and Gcode from RhinoCam. I have mach3 set to stop and wait upon tool change.
It happened specifically here:
X-0.4673 Y-0.1964
X-0.5287 Y-0.3053
Z0.1250 F15.0
(Deep Drill )
G00 Z0.0000
G00 X0.0000 Y0.0000
M6 T8
M03 S10000
X0.0000 Y0.0000 Z0.1141
G83 X0.0000 Y0.0000 Z-0.3 R0.1 Q0.05
G80
G01 Z0.1141 F4.0
(2 1/2 Axis Pocketing)
G00 Z0.0000
G00 X0.0000 Y0.0000
M6 T2
M03 S10000
X-0.1066 Y-0.1975 Z0.0312 F15.0
Z-0.0196 F1.0
X0.1066 F3.0
X0.1177 Y-0.1911
X0.2244 Y-0.0064
Y0.0064
X0.1177 Y0.1911
X0.1066 Y0.1975
X-0.1066
X-0.1178 Y0.1911
X-0.2244 Y0.0064
Y-0.0064
X-0.1177 Y-0.1911
X-0.1066 Y-0.1975
Z-0.0392
X0.1066
X0.1177 Y-0.1911
X0.2244 Y-0.0064
Y0.0064
X0.1177 Y0.1911
X0.1066 Y0.1975
X-0.1066
Instead of deep drilling at 4 ipm, it did it at my Z motor tune speed of 12.... Then instead of profiling at 3 IPM it went at 20. The FRO says the correct speed... but units/min says the motor tune speed...
Is there some setting in general config I may be missing?
I am certainly no expert with G Code but from what I see above you are going straight from G0 moves into your feed moves but you have no G1's there so the G0 are still in effect.
You are also adding an F word to a G00 line which is invalid.
G00 X0.0000 Y0.0000 <<------- G00 mode starts here
M6 T2
M03 S10000
X-0.1066 Y-0.1975 Z0.0312 F15.0 <<<------ still in G00 mode, F word has no effect
Z-0.0196 F1.0
X0.1066 F3.0
X0.1177 Y-0.1911
X0.2244 Y-0.0064
So Mach is doing exactly what it is programmed to do.
Damn machines always run the actual code, not what you want it to be. :-)
This is the problem with what I call "short" programming.
When writing my code, I always put in the complete line e.g. G0 X0 Y0, not just the co-ordinates I want to move to. Similar when I want a cutting move, G1 F4 X3 Y3. It makes it a lot easier to check the code when something like this happens, because you don't have to trace back to see what the machine is actually doing..
Unfortunately if you use a CAM program, you are stuck with what it gives you.
